QoS on a non trunk Interface
Answered Question
Dec 3rd, 2008
  • Silver, 250 points or more
I am new to QoS and would like to setup auto QoS between my site and another site. Below is what I intend to implement on my switch (Cisco 6506-e) SUP720. Is this good enough?
switch(config)#mls qos
switch(config)#mls qos map cos-dscp 0 8 16 24 32 46 48 54
switch(config-if)#ip address x.x.x.x/30
switch(config-if)#mls qos trust cos
Correct Answer by mihanlin about 8 years 4 months ago
One suggestion for change:
Instead of mls qos trust cos, do mls qos trust dscp
As CoS is only sent in 802.1q header (i.e. a trunked interface), it won't work. Trusting DSCP will work perfectly for L3 interfaces.
Other than that, what you have there is fine for a basic config.
Overall Rating: 5 (1 ratings)
Correct Answer
mihanlin Thu, 12/04/2008 - 01:21
Tshi M Thu, 12/04/2008 - 05:42
thanks much for the quick reply.
