ACE source IP based predictor
Dec 3rd, 2008
I know that if we use source IP based predictors, the ACE would use a hash of the source IP to load balance the traffic. Is there is capability to make this process deterministic. In other words, I have tthree client subnets accessing the web servers on the same VIP. I want the traffic from subnet 1 to go to server 1 and traffic from subnets 2 and 3 to be loadbalanced to the rest of the servers
any idea on how to get this done ?
sachinga.hcl Thu, 12/04/2008 - 00:00
  • Silver, 250 points or more
HI Dinuka,
Session persistence (stickiness) based on client source IP address or HTTP cookies are recommended to be configured on the Cisco ACE for this flow.
IP Address Stickiness
You can use the source IP address, the destination IP address, or both to uniquely identify individual clients and their requests for stickiness purposes based on their IP netmask. However, if an enterprise or a service provider uses a megaproxy to establish client connections to the Internet, the source IP address no longer is a reliable indicator of the true source of the request. In this case, you can use cookies or one of the other sticky methods to ensure session persistence.
Here can be the sample configuration:
resource-class websrv
limit-resource all minimum 0.00 maximum unlimited
limit-resource sticky minimum 20.00 maximum equal-to-min
rserver host webserver1
ip address 10.10.10.1
inservice
rserver host webserver2
ip address 10.10.10.2
inservice
rserver host webserver3
ip address 10.10.10.3
inservice
serverfarm host werbsrv1only
probe websrv
rserver webserver1 1000
inservice
serverfarm host werbsrv123
probe websrv
inservice
rserver webserver2 1000
inservice
rserver webserver3 1000
inservice
ACE receives requests to the VIP on port 80 and translates them to port 1000 using the server farm configuration shown above.
The link to the websrv home page is http://websrv:1000/index.html. A probe to this link is configured on ACE as follows:
probe http websrv
port 1000
interval 2
faildetect 2
passdetect interval 2
request method get url /index.html
expect status 200 200
Session persistence can be established by tying the session to an IP address, that uniquely identifies the client.
Create a sticky-group
sticky ip-netmask 255.255.255.255 address source Client_subnet_1
timeout 10
serverfarm werbsrv1only
Change the server farm to the sticky-group:
policy-map type loadbalance first-match basic-slb
class class-default
sticky-serverfarm werbsrv1only
sticky ip-netmask 255.255.255.255 address source Client_subnet_2
timeout 10
serverfarm werbsrv123
sticky ip-netmask 255.255.255.255 address source Client_subnet_3
timeout 10
Here you can find the details in the below url :
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/sticky.html#wp1004411
I have also attached a jpeg for your reference.
Hope you will get the idea how to use the sticky based on IP address.
Here you can find sample config of similar type:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/prod_white_paper0900aecd804edab0.html
Thanks and regards,
Sachin Garg
Senior Specialist Security
HCL Comnet Ltd.
http://www.hclcomnet.co.in
A-10, Sector 3, Noida- 201301
INDIA
Mob: +91-9911757733
Email: [email protected]
thedinuka Thu, 12/04/2008 - 00:54
Hi Sachin
Thanks for the detailed response. Still a small detail is not clear to me. hope you wouldn't mind me asking another question.
I see that the server farms are defined with sticky configurations based on source ip and the netmask. But with this do i have specific control over to which serverfarm a specific clients request would go to.
For example, i need client subnet 192.168.1.0/24 to go to rserver1 and client subnet 192.168.2.0 to be load balanced to rserver2 and rserver3. clients in both subnets are sending packets to the same destination VIP
hope this is clear
Gilles Dufour Thu, 12/04/2008 - 01:07
  • Cisco Employee,
you will need to create 2 serverfarms.
1 with rservers to be used by clients from subnet 192.168.1.0/24 and the other serverfarm with rserver2 and rserver3 to be used by other clients.
You then need to create class-map to match on src ip ie:
class-map type http loadbalance match-all ClientX
2 match source-address 192.168.1.0 255.255.255.0
Finally, in your policy-match, you assign the src class-map with the appropriate serverfarm
ie:
policy type loadbalance first-match MyPolicy
class ClientX
serverfarm1
class class-default
serverfarm2
If you need stickyness, you can replace the serverfarm with a sticky-serverfarm.
You can also configure serverfarm2 as a backup-serverfarm for serverfarm1.
Gilles.
sachinga.hcl Thu, 12/04/2008 - 01:37
HI here is the syntax for :
Sticky IP configuration mode commands allow you to create a sticky group for IP address stickiness. To
create a sticky group and access sticky IP configuration mode, use the sticky ip-netmask command. The
prompt changes to (config-sticky-ip). Use the no form of this command to remove the sticky group from
the configuration.
sticky ip-netmask netmask address {source | destination | both} name
no sticky ip-netmask netmask address {source | destination | both} name
