Collin Clark Thu, 12/04/2008 - 06:46
  • Purple, 4500 points or more
Do you mean to and from the router (eg copying new IOS) or do you mean NATing through the router?
sujitkr7cisco Fri, 12/05/2008 - 01:28
Dear Collin,
i wnat to the ftp user access remotly to the different portd ,not through default FTP port -21.which is the best and most secure.
Thanks for reply.
Sujeet
Collin Clark Fri, 12/05/2008 - 05:55
OK- Let's assume the server is running on port 21, but you want users to connect to 2121 for FTP. You'll need to create a NAT translation.
<font size="3">ip nat inside source static tcp 192.168.0.1 21 interface [public ip] 2121 </font>
Don't forget to allow TCP 2121 in your ACL.
Hope that helps.
