Nokia E66 EAP-TLS error
jmprats
Level 4
Level 4
Hi, I am configuring a Nokia E66 (wich is v4 in Cisco Compatible Extensions, so it supports EAP-TLS) with WPA2 EAP-TLS against IAS in a Cisco Wireless Network and I always obtain the same error in the IAS event viewer.
denied accesss
Authentication-Type = EAP
EAP-Type = Smart Card or other certificate
Reason-Code = 16
Reason = Authentication was not successful because an unknown user name or incorrect password was used.
Has anybody tried E66 with EAP-TLS?
Any experiences?
pasimahone
Could you send details of your wlan setup in Nokia device?
-Pasi-
Yes, this is my setup
- hidden network
- infraestructure
- security: WPA/ WPA2
- EAP
- Plug -ins: EAP-TLS. I select the user certificate and the CA certificate. User name from the certificate, domain from the certificate
- WPA2 only mode
In the IAS log, the username is correct, but always appear this strange error. The certificates and infraestructure I use it works well in a notebook
Could you check the following from the Certificate:
'Issuer Alternative Name' and 'Subject Alternative Name' fields are not empty and
'Non Repudiation' field is not in use.
-Pasi-
Hi Pasi,
I only have the field 'Issuer', I don't have 'Issuer Alternative Name'. I have 'Non Repudiation' in the intermediate CA certificate, but not in the user certificate.
I'm using certificates with a public key of 2048 bits in the user and 4096 in the CA. I don't know if this can be a problem
Thanks for your interest.
