ICM Call Transfer
Dec 4th, 2008
HI,
I wanted to transfer a call from ICM to an ip-phone in call manager.
What happens is, CVP plays welcome message and collects the extension number and passes it to ICM script, I am using a label node to pass the label(extension number) to CVP routing client.
In CVP I have a static route "1>" pointing to call manager.
Ideally I assume when i pass the extension number as a label to CVP and from CVP to CM using a sip static route the call should land on the ip phone extension number. But the call gets disconnected..
Is my understanding correct...
Pls suggest...
rafi.imran Fri, 12/05/2008 - 04:36
1569: 192.168.10.47: Dec 05 2008 18:03:13.919 +0530: %CVP_4_0_SIP-3-SIP_INTERNAL_ERROR: B2BUA is not configured with a route for making calls to [9191]. Please add this route. [id:5005]
1570: 192.168.10.47: Dec 05 2008 18:03:13.919 +0530: %CVP_4_0_SIP-3-SIP_CALL_ERROR: CALLGUID = F0DB73B6-C20011DD-85D098AA-3F69BEFA LEGID = 1228480393919804 - [OUTBOUND] - DsSipInvitation - ;tag=1187251589 - 1 INVITE REJECTED WITH 503 - Service Unavailable Warning: 399 "Routing failed: ccbid=30 socket=192.168.10.47:5060"
[id:5004]
1571: 192.168.10.47: Dec 05 2008 18:03:13.935 +0530: %CVP_4_0_SIP-3-SIP_CALL_ERROR: CALLGUID = F0DB73B6-C20011DD-85D098AA-3F69BEFA LEGID = F0DE8116-C20011DD-85D598AA-3F69BEFA - [INBOUND] - DIALOGUE_FAILURE from ICM Router sends 500 rejection to call. [id:5004]
1572: 192.168.10.47: Dec 05 2008 18:03:15.919 +0530: %CVP_4_0_SIP-3-SIP_CALL_ERROR: CALLGUID = F0DB73B6-C20011DD-85D098AA-3F69BEFA LEGID = F0DE8116-C20011DD-85D598AA-3F69BEFA - [INBOUND] - ABNORMALLY ENDING - SIP code [500], Reason Hdr [SIP;cause=500] Internal Server Error, GW call using SURV TCL flag [false], NON NORMAL flag [true], USE ERROR REFER flag [true] with AGE (msecs) 8219 and Call History: 777777771219, 1158, [id:5004]
1573: 192.168.10.47: Dec 05 2008 18:03:15.919 +0530: %CVP_4_0_SIP-3-SIP_INTERNAL_ERROR: B2BUA is not configured with a route for making calls to [9292]. Please add this route. [id:5005]
1574: 192.168.10.47: Dec 05 2008 18:03:15.919 +0530: %CVP_4_0_SIP-3-SIP_CALL_ERROR: CALLGUID = F0DB73B6-C20011DD-85D098AA-3F69BEFA LEGID = F0DE8116-C20011DD-85D598AA-3F69BEFA - [INBOUND]: Destination URL is null, cannot make the REFER. [id:5004]
1158 is the ip-phone extension number
david.macias Thu, 03/26/2009 - 10:01
did you ever get a resolution for this? we're seeing similar errors.
thank you,
david
Chris Deren Thu, 03/26/2009 - 18:16
Make sure the CSS on the SIP trunk has access to the parition of the phone DN, also ensure there is no digest authentication enbaled on the SIP security profile.
HTH,
Chris
