Changing Text in Black Bar of IP Phone (7941/61/71 etc...)
Dec 4th, 2008
  • Bronze, 100 points or more
I have a client running CM 6.1 who needs to change the extension display in the top right-hand corner on an IP Phone to the user's name or another Text Based field.
By default the display in the top right shows the extension number assigned to line 1. I have changes this in CME once or twice and losely remember that the phones will only display 14 characters but cannot for the life of me remember how to do this in CM.
Any help would be greatly appreciated.
Thanks in Advance,
Dave
Overall Rating: 3.5 (2 ratings)
egarcia9330 Thu, 12/04/2008 - 01:48
In CME you can change the text of the black bar by entering a string on 'description' under the ephone-dn configuration.
If you have multiple ephone-dn assigned to an ephone, it will take the 'description' value of button #1.
IE:
ephone-dn 3
description LABEL
exit
davetucker Thu, 12/04/2008 - 02:01
I already know how to do this in CME.
This question relates to Unified Communications Manager 6.1.
j.mccartney Thu, 12/04/2008 - 06:16
I think what you are referring to is the mask that is displayed to callers. Go under the line settings and change the line that says "External Phone Number Mask" - that is the field that is displayed in the top right corner of the IP phones. HTH's.
Rob Huffman Thu, 12/04/2008 - 06:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dave,
This is available in CME only, not CCM at this point in time;
Sadly, the "External Phone Number Mask" that John nicely noted (where this info is populated) only supports numbers, the letter X,* and #
Hope this helps!
Rob
davetucker Fri, 12/05/2008 - 04:59
Thanks All.
Manipulating the External Phone Number Mask will almost fits the bill! I am surprised that Cisco do not offer this on CM especially as CME and the 7900 range of phones appear to support this facility.
Thanks again,
Dave
