Attendant Console
moropodi2008
I installed an attendant console on one of my sites and it was fine for two weeks. Now the receptionist can login and she is on line but its not showing her who is ready, busy,etc , its only showing question marks (???). Thanks.
Rob Huffman
Hi James,
Try this;
Go to Cisco Unified Serviceablity
Go to Tools>Control Centre - Feature Services> Attendant Console Server Service >Stop/Start
Hope this helps!
Rob
5 Replies 5
seaman0555
i'm using CCM6.1 and they are no firewall rules on her machine.Thanks for ur response
Sounds like the lines are not allowing AC to control them via CTI.
Do you have the "ac" Application User created and added to the "Standard CTI Enabled group", the "Standard CTI Allow Call Park Monitoring group", and the "Standard CTI Allow Control of All Devices" user group
Do you also have the "ACDeviceAuthenticationUser" Application user created and associated with the Receptionist Phone and the AC Pilot points?
For more info look at the CM 6.1 Features and Services guide http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsccmac.html
HTH,
Please rate helpful posts.
Dave
Rob Huffman
Hi James,
Try this;
Hope this helps!
Rob
Thanks its working.
