6509 not supported in RME 4.0.6 ??
Dec 4th, 2008
One of my customers has 2 6509 switches and is running Ciscoworks LMS 2.6 with RME 4.0.6 .
I created a credential jobs and it seems that 6509 are not supported . I verified his archiving and the configs are not backupped .
I was convinced that until now the configuration was archived and the only change we made was last week . We upgraded then to RME 4.0.6 .
Has anybody seen this problem ?
PS : We are running 6509 with IOS 12.1(18)SXF7 so there is not catos :-)
Joe Clarke Thu, 12/04/2008 - 11:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is almost certainly an RME package problem. I'll bet you're running on Windows. Please post the list of contents of NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/rme.
wim_depauw Mon, 12/08/2008 - 05:39
I'm at the customer tomorrow or on thursday , I'll send you the information then .
Thx for the quick reply
wim_depauw Tue, 12/09/2008 - 01:46
Hi Joe,
I checked both directories and saw that in the NMSROOT/www there a cat6000 and cat6000ios.zip files that are missing in the nmsroot/mdc . Do I need to copy them ?
gr
wim
wim_depauw Tue, 12/09/2008 - 02:35
Joe,
Copied the files and the devices are supported now .
The only bizar thing is that I'm not able to synchronize the startup config of one of the core switches .
He gives me the message internal error.
