rate-limit on cisco 851
Dec 4th, 2008
Hi all.
I connect remote office via dlc modem and cisco 851 router and can't limiting bandwich on WAN (FastEthernet4) interface.
I use following config for FastEthernet4:
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
bandwidth 320
ip address
no ip redirects
no ip unreachables
no ip proxy-arp
rate-limit input 312000 8000 8000 conform-action transmit exceed-action drop
rate-limit output 312000 8000 8000 conform-action transmit exceed-action drop
ip route-cache flow
duplex auto
speed auto
But, rate-limit command not working properly.
May be Cisco 851 router not support this feature?
crow930us Sun, 12/07/2008 - 09:07
Check your IOS version.
It looks like the 12.3 and 12.4(6)T6 versions and earlier don't support the rate limit feature but the 12.4(9)T3 versions and later do.
leahcheremisin Sun, 12/07/2008 - 23:59
My version IOS - Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T6, RELEASE SOFTWARE (fc2)
rate-limit command is available on my Cisco 851. But I don't see any changes in bandwidth limiting.
I measure bandwidth via iperf utilities before and after enabling rate-limit on FastEthernet4 port.
