Cisco Configuration Professional error message
Answered Question
Dec 4th, 2008
I would like to test this application but, after the start on main window I become the following error message:
"An internal error has occurred. Cisco CP will shutdown.
Restart Cisco CP and discover the devices again."
And than:
"Internal error: Failed to load resource file URL information for the Wireless application launch. error : HTTP request error"
The OS is Windows XP SP2 and I tried with IE 6 and 7.
What can be the problem?
Correct Answer by mchin345 about 7 years 10 months ago
Please make sure that the PC being used meets the minimum requires for
using Cisco CP. Specifically the Java Runtime version needs to JRE
Min Requirement:
Overall Rating: 5 (1 ratings)
mcaldogne Thu, 12/11/2008 - 00:36
The problem is solved, I had an old 1.4 java version, updated to 1.6.
I deinstalled java complitely and reinstalled the latest version.
Thank you for helping.
