Remote Access VPN to Home Network on ASA 5505
Dec 4th, 2008
Hi All,
My goal is to allow my friend to use the Cisco VPN Client to connect to my home network. I have the ASA 5505.
I used the VPN Wizard to set things up, but I wasn't sure what to do in the NAT section so I left it blank. My friend is connecting from a local network of and my local network (inside) is
1. I was wondering if someone could look at the configuration I have so far, and let me know if I am on the right track and if I need to change anything.
2. When my friend uses the Cisco VPN Client, will he be using 'Enable Transparent Tunneling' & 'IPSec over UDP (NAT / PAT)'? Any other special options that he will need to set to connect?
Here is a link to my configuration:
Thank you so much for any help and guidance!
Best Regards,
mike_guy29 Fri, 12/12/2008 - 03:52
The link you provided does not work. Are you able to post your config and I will take a look.
