Gilles Dufour Fri, 12/05/2008 - 03:02
  • Cisco Employee,
You can only do it through a redirect.
Otherwise, instead of inserting the string into the url, you could insert it inside the header.
You will have to modify your application to look into the header instead of the url.
Gilles.
lucbisson Fri, 12/05/2008 - 05:42
Thank's Gilles. We tried it in the header but it seems that on the request side, the header was not inserted. Only in the response. Is there a parameter that we can set on the ACE to allow insertion while the request is done?
