FWSM ACL error
Dec 4th, 2008
Anybody have any idea what this FWSM error message means? According to "sh resource acl", I'm only using about 20% of the available ACEs.
Cebalrai/BANNER# config t
Cebalrai/BANNER(config)# access-list sctprod-ingress line 20 extended permit tcp host abc host xyz eq 21
ERROR: <sctprod-ingress> element cannot be created
Cebalrai/BANNER(config)# q
Overall Rating: 5 (1 ratings)
ajagadee Thu, 12/04/2008 - 08:51
In the past, I have seen this error message pop up whenever you try to add an access-list that already exists. Can you look at the running configuration and make sure the ACL that you are trying to add is not existing in the config.
*Pls rate if it helps*
lowen Thu, 12/04/2008 - 12:38
Right you are ... the ACE already exists. Thanks.
