Restricting max connections per local host
Dec 4th, 2008
We have an ASA 5505 running 8.0. Users connected to the internet through this device report very slow response time. show local-host is showing one particular host with 75+ TCP connections and 50+ UDP connections. We suspect a problem with this machine. The "Intercepting and Responding to Network Attacks" document describes how to set max-conn but it seems to be per interface or global. Is there a way to set max connections per local host?
ajagadee Thu, 12/04/2008 - 08:58
  • Cisco Employee,
With MPF on the ASA, this should be possible. For example:
access-list 100 permit ip host x.x.x.x any
class-map ONEUSER
match access-list 100
policy-map MAXUSERCONNECTIONS
class ONEUSER
set connection per-client-max 10
service-policy MAXUSERCONNECTIONS interface inside
Arul
*Pls rate if it helps*
