cannot ping segment through L2L
Dec 4th, 2008
I have a site-to-site vpn tunnel between two sites that works very well. However there is one segment on one of the ends that is not reachable. This is the error message I get when I attempt to ping:
1|Dec 04 2008 17:01:40|106021: Deny ICMP reverse path check from 10.0.166.3 to 192.168.200.1 on interface inside
4|Dec 04 2008 17:01:40|400014: IDS:2004 ICMP echo request from 10.0.166.3 to 192.168.200.1 on interface inside
4|Dec 04 2008 17:01:38|400014: IDS:2004 ICMP echo request from 10.0.166.3 to 192.168.200.1 on interface inside
1|Dec 04 2008 17:01:36|106021: Deny ICMP reverse path check from 10.0.166.3 to 192.168.200.1 on interface inside
4|Dec 04 2008 17:01:36|400014: IDS:2004 ICMP echo request from 10.0.166.3 to 192.168.200.1 on interface inside
1|Dec 04 2008 17:01:34|106021: Deny ICMP reverse path check from 10.0.166.3 to 192.168.200.1 on interface inside
4|Dec 04 2008 17:01:34|400014: IDS:2004 ICMP echo request from 10.0.166.3 to 192.168.200.1 on interface inside
The security policy (nonat + crypto's) include this segment, so that's not the issue.
Any idea?
ronshuster Thu, 12/04/2008 - 12:24
You are right, the firewall was missing a route to the internal network. thank you.
