Private password phrase recovery
Answered Question
Dec 4th, 2008
Hi All,
Our ccm 4.1.3 system was set up before I started and I now need the "private password phrase" to reinstall cdr.
Anyone know how to recover password?
Randall
Correct Answer by jbarcena about 8 years 4 months ago
You can use Adminutility tool to reset the Private password phrase, this tool only runs on
the Publisher and needs to be done after hours since it stops services; here is the path
and the steps to run it.
C:\ProgramFiles\Cisco\Bin\adminutility.exe
Log into the utility as Administrator and select the very top checkbox to select all
accounts. Then go to Options and Set new password
It will ask you for the password phrase, and the tool will run, everything keeps working
fine after the tool finishes.
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 12/04/2008 - 10:42
  • Cisco Employee,
  • Hall of Fame,
    2011
unfortunately you cannot recover it, only reset it using the adminutility tool
java
if this helps, please rate
rcrumm_2 Thu, 12/04/2008 - 11:55
where can i get the tool and do I need to do this off-hours.
Also is there a document for the tool?
Randall
thisisshanky Thu, 12/04/2008 - 11:58
  • Purple, 4500 points or more
search for this in Callmanager C drive
Correct Answer
jbarcena Thu, 12/04/2008 - 12:05
  • Red, 2250 points or more
jcarlyle Tue, 04/14/2009 - 11:52
does running the tool stop services on the subscribers as well? With no phones registered to the publisher its not such a big deal to reset the cm service on it. If the subscribers are reset its more of an issue to the end user.
