Reset Password Administrator CAR (CDR Analysis Report)
Answered Question
Dec 4th, 2008
Hi Guys,
We lost the password administrator the service CAR. Is there any procedure to reset the password administrator to service CAR. The version of CallManager is 4.2.1.
Thank You,
Wilson Santana
Correct Answer by Jaime Valencia about 8 years 1 month ago
ok, the procedure i already posted is used to reset the pwd from and admin user. if you don't know it you cannot log into CAR, if you want to add new users to admin group, you need to log into CAR
java
if this helps, please rate
Overall Rating: 4.5 (3 ratings)
wilsonsant Fri, 12/05/2008 - 10:06
Hi Javalenc,
Thanks for the documentation.
In this doc explains how I can change the password of one user or reset the password of the admin user. But if I reset the admin password, I'll lost all users configured. Is it possible I discover or reset the admin password, without lost all configured users ?
Thanks a lot,
Wilson
Jaime Valencia Fri, 12/05/2008 - 10:21
????????? if you reset the password from the admin user, all you do is reset the password from an admin user!
i don't know who told you or why you're involving losing all the config just for resetting the pwd to get into CAR
you simply find a user thru DCD, go to CCM directory, reset the pwd, and that's it
java
wilsonsant Fri, 12/05/2008 - 11:07
Hi Javalenc,
It's not clear. Our problem is, don't have the password administrador and only with passowrd administrator will can input new user, right? Could you send for me the procedure to include new users?
Thank You,
Wilson
Correct Answer
Jaime Valencia Fri, 12/05/2008 - 13:16
java
wilsonsant Fri, 12/05/2008 - 16:21
Hi Javalenc,
After solved the problem with password administrator, I need know with I create a new user common. Do you understand?
Thank You,
WIlson
