low bandwidth issue on switches 3560
Dec 4th, 2008
I am currently having cross switch issues, but did some testing between clients on the same switch and noticed very slow transfer times between clients on the same switch as well. I looked at the ports and the incoming/outgoing was very low. The ports are 10/100 set to Auto/100/full and are on the same VLAN. Checking the 5 minute average the bandwidth does not even get close to 100Mb, in fact is slowly ticks up to toward 15Mb.
Here are some numbers on file copies:
160 MB = 40 secs (should be around 10-15 secs)
2.5 GB = 3+ minutes
Any help on where to look would be appreciated.
mariov652 Thu, 12/04/2008 - 12:51
I'm sure you've checked this already, but have you checked all clients are forced to 100/Full and all respective switch ports are manually set to 100/Full?
May be that one or more systems are using half duplex.
I take it you already upgraded the client's drivers to the latest versions?
Simple little checks, but that can make the difference.
ropethic Thu, 12/04/2008 - 15:01
I agree.
perform a show interface on the client to check for FCS, aligment, runt errors
archari Thu, 12/04/2008 - 15:52
A quick cable sanity check might help too. Do the cables work fine when moved to another switch (if you have one handy?)
