12-04-2008 12:13 PM - edited 03-18-2019 10:06 PM
I have a QSIG PRI trunk configured on a 3825 GW. I am currently tracking the number of channels being used for that QSIG interface using RTMT. I would like to go one step further and actually monitor the extensions (called number) that are hitting that trunk. Is there a way to track that?
I appreciate your help!
Marvin
12-04-2008 02:23 PM
do you want to use RTMT for this purpose?? because it doesn't go that far.
also, do you want a report or do this live??
java
if this helps, please rate
12-04-2008 03:25 PM
Hi java,
I don't need to uses RTMT. Any method (historical report or live) that will enable me to see total calls as well as called numbers based on time/duration of day will work.
Marvin
