Selecting a router to terminate a T3 Circuit?
Dec 4th, 2008
We have a new T3 circuit to terminate.
Will a 2811 router, T3 module included, handle the job? I'd like to save the cost difference of a 3825 router.
Collin Clark Thu, 12/04/2008 - 14:19
  • Purple, 4500 points or more
A 3825 supports a DS3 with no services and 3845 supports a DS3 with services. Those are the minimums.
Hope that helps.
Joseph W. Doherty Thu, 12/04/2008 - 15:34
With complex QoS, I've seen a 2811 handle about 20 Mbps (duplex) on a T3, where it tops out the CPU. From its Mpps rating, a 2851 might just about handle a T3, but haven't seen one in action.
Much depends on just how much traffic you'll routinely push across the T3. In my case of the 2811 on a T3, normal traffic doesn't usually exceed 10 to 15 Mbps on the T3, and at that volume level, it seems to work well.
archari Thu, 12/04/2008 - 16:22
  • Cisco Employee,
Are you just terminating the T3 for routing or will you be running any services over it?
