DMZ to INSIDE access
Dec 4th, 2008
I have a device off the DMZ interface of the firewall (PIX\ASA) and it requires access to a number of hosts on the inside (and vice versa) on a number of ports.
Does this require a NAT? ACL?
Can you provide an example?
Overall Rating: 5 (1 ratings)
John Blakley Thu, 12/04/2008 - 13:33
  • Purple, 4500 points or more
Assuming you have the following:
DMZ Subnet: 192.168.1.0
Inside Subnet: 10.10.10.0
Try:
static (inside,dmz) 10.10.10.0 10.10.10.0 netmask 255.255.255.0
acl dmz permit tcp 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255 eq 25
acl dmz permit tcp 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255 eq 80
access-group dmz in interface dmz
You'll need to create an access list entry for each port you want, and you'll need to have an acl on the outside interface allowing traffic into your network. This is from memory, so I hope it works. :-)
HTH,
John
ronshuster Mon, 12/08/2008 - 11:06
John,
What is the purpose of this line:
I am looking for one specific server on the dmz to communicate with one specific server on the inside on a number of specific ports. All other devices on the inside should not be able to communicate with any device on the dmz.
Would the above restrict these conditions?
ronshuster Mon, 12/15/2008 - 07:15
i am unable to get this to work.
My dmz IP address : 172.20.0.6
My inside : 192.168.4.0\24 & 192.168.5.0\24
My config is:
static (inside,dmz) 192.168.4.0 192.168.4.0 netmask 255.255.255.0
static (inside,dmz) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
access-group dmz_out in interface dmz
access-list dmz_out extended permit tcp host 172.20.0.35 host 10.20.4.161 eq smtp
access-list dmz_out extended permit tcp host 172.20.0.35 eq smtp host 10.20.4.161
access-list dmz_out extended permit ip any any
I am unable to ping from 172.20.0.6 to any of the 192.162.4 or 5 addresses.
Any idea?
ronshuster Mon, 12/15/2008 - 07:52
hostname **********
domain-name default.domain.invalid
enable password ************* encrypted
names
dns-guard
interface Ethernet0
description OUTSIDE
speed 10
duplex full
nameif outside
security-level 0
ip address **********
interface Ethernet1
description 100
nameif inside
security-level 100
ip address 10.20.99.33 255.255.255.240
interface Ethernet2
description dmz
nameif dmz
security-level 50
ip address 172.20.0.1 255.255.255.0
passwd ************* encrypted
banner exec LINE
ftp mode passive
dns domain-lookup outside
dns name-server ***********8
object-group service IPSS-TCP tcp
port-object eq 5023
port-object eq https
port-object eq 3389
port-object eq 5022
port-object eq ssh
port-object eq telnet
port-object eq 69
object-group service IPSS-UDP udp
access-list inside_out extended permit ip any any
access-list inside_out extended permit icmp any any
access-list outside_incoming extended permit tcp any host ***********8 eq smtp
access-list outside_incoming extended permit tcp any host *********** eq https
access-list outside_incoming extended permit tcp any host *********** eq www
access-list dmz_inside extended permit ip any any
access-list allownatout extended permit ip 10.20.0.0 255.255.0.0 any
access-list allowdmzout extended permit ip 172.20.0.0 255.255.255.0 any
access-list outside_cryptomap_20 extended permit ip 192.168.4.0 255.255.255.0 172.16.50.0 255.255.255.0
access-list outside_cryptomap_20 extended permit ip 192.168.4.0 255.255.255.0 172.16.70.0 255.255.255.0
access-list outside_cryptomap_20 extended permit ip 192.168.4.0 255.255.255.0 10.42.0.0 255.255.0.0
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 access-list allownatout
nat (inside) 0 10.20.4.161 255.255.255.255
nat (dmz) 1 access-list allowdmzout
static (inside,dmz) 10.20.4.161 10.20.4.161 netmask 255.255.255.255
static (inside,dmz) 10.20.4.140 10.20.4.140 netmask 255.255.255.255
static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
access-group outside_incoming in interface outside
route outside 172.22.4.0 255.255.255.0 ******** 1
route outside 0.0.0.0 0.0.0.0 ******** 1
route inside 192.168.200.0 255.255.255.0 10.20.99.36 1
route inside 192.168.4.0 255.255.255.0 10.20.99.36 1
route inside 192.168.100.0 255.255.255.0 10.20.99.36 1
route inside 10.20.4.140 255.255.255.255 10.20.99.36 1
route inside 10.20.4.141 255.255.255.255 10.20.99.36 1
route inside 10.0.107.0 255.255.255.0 10.20.99.36 1
route inside 10.0.0.0 255.0.0.0 10.20.99.36 1
route inside 10.20.4.128 255.255.255.128 10.20.99.36 1
route inside 10.20.4.161 255.255.255.255 10.20.99.36 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect esmtp
inspect http
inspect icmp
service-policy global_policy global
Cryptochecksum:9ac58aa592c9a77984d18af3b5864def
: end
John Blakley Mon, 12/15/2008 - 09:48
Ron,
You'll need to have an access list applied to your inside interface for your dmz to be able to access it.
Try creating one that allows everything for the time being, and then apply it to the inside interface.
HTH,
John
cisco24x7 Mon, 12/15/2008 - 10:44
  • Silver, 250 points or more
why does he need access-list applies on the
inside interface? The default is that "inside"
has the priority of 100 so it can go just about
everywhere?
John Blakley Mon, 12/15/2008 - 10:46
Maybe I read it wrong, but his original statement:
"I am unable to ping from 172.20.0.6 to any of the 192.162.4 or 5 addresses."
Tells me that he's trying to go from DMZ (lower security) to inside (higher security) meaning he needs an ACL to allow that traffic through. Am I incorrect?
John
ronshuster Mon, 12/15/2008 - 10:54
That is correct, I am unable to ping from 172.20.0.6 which is on the dmz to the inside segments 192.168.4.0 & 192.168.5.0.
I have an ACL that ends with permit ip any any on all incoming traffic to the dmz
should this not allow traffic from the dmz access the inside?
Also I have the translations for the two inside segments:
What else is required to allow traffic from the dmz to the inside?
John Blakley Mon, 12/15/2008 - 10:58
Can you ping to a host in the DMZ from an inside host? Does that part work?
John Blakley Mon, 12/15/2008 - 11:04
Ron,
I also noticed that your 192.168.4.0 subnet gets routed through another device at 10.x.x.36. Is this a proxy server or another router?
John
Jon Marshall Mon, 12/15/2008 - 11:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ron
Your 192.168.4.x and 192.168.5.x subnets are not directly connected to the ASA inside interface.
So you need to check the routing back to the ASA ie. do your 192.168.4 & 5.x clients know how to route back to 172.20.0.x network.
As John has asked what is device 10.20.99.36 and does this device know how to route to 172.20.0.x network.
Try ping 10.20.99.36 from the DMZ, does it work or not ?
Also try ping 192.168.4.x client from the ASA - does that work ?
By the way you don't need an acl applied to the inside interface.
Jon
John Blakley Mon, 12/15/2008 - 11:19
Also, I think you can remove:
I don't see that ACL anywhere. And yes, you don't need the ACL. I was mistaken, and I've since looked at another config to see what I was thinking and it was something totally different. :-)
John
ronshuster Mon, 12/15/2008 - 12:29
I can ping from the inside to the dmz, ie. server from 192.168.4.0 can ping 172.20.0.6
but not the other way (this is where the problem is)
routes from the firewall to the internal network is 10.20.99.36, that is a demarc vlan between the core switches and the firewall where 10.20.99.36 is the hsrp address on the core (cat6500)
192.168.4.x & 192.168.5.x are routed on the core switches
the real ip address of the demarc vlan (10.20.99.34) CAN ping 172.20.0.6
but again, not the other way
I did not try to ping the demarc vlan (10.20.99.36) from the dmz (172.20.0.6), but again, the other way works.
Take a look at this example (DMZ to Inside):
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807fc191.shtml
I noticed that the static nat here is different than what I have. In my config I am not doing any translation, ie:
where on their example (URL) they are translation, ie:
ASA-AIP-CLI(config)# static (inside,DMZ) 192.168.2.20 172.20.1.5 netmask 255.255.255.255
That is the only difference I can find between the two
Jon Marshall Mon, 12/15/2008 - 12:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Can you add this to your config and retry
access-list nonat permit ip 172.20.0.0 255.255.255.0 192.168.4.0 255.255.255.0
access-list nonat permit ip 172.20.0.0 255.255.255.0 192.168.5.0 255.255.255.0
nat (dmz) 0 access-list nonat
Jon
John Blakley Mon, 12/15/2008 - 12:50
Jon,
In your example, does:
static (inside, dmz) 192.168.4.0 192.168.4.0 netmask 255.255.255.0
OR
static (inside, dmz) 172.20.0.0 192.168.4.0 netmask 255.255.255.0
do the same thing as your example?
Thanks!
John
Jon Marshall Mon, 12/15/2008 - 13:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
Reason i suggested the addition was because of this line in the config -
and the accompanying acl -
This is quite unusual in that usually on the DMZ you have servers you want accessed from the Internet so you can't use dynamic NAT as above, you need static statements.
So i was wondering if a connection initiated from the DMZ hit the nat statement on the dmz interface but then found no corresponding global statement on the inside interface. Note that traffic destined to 192.168.4/5.x would match the acl above. So i suggested a nat exemption for traffic from the DMZ to the inside. Not 100% sure it will work but i suspect this is the issue.
In answer to your direct question neither statement matches what i have suggested -
means 192.168.4.x is presented as 192.168.4.x to the DMZ and the dmz can initiate connections to 192.168.4.x from the DMZ.
means 192.168.4.x addresses are presented to the DMZ as 172.20.0.x addresses and the dmz can initiate connections to 172.20.0.x when it wants to talk to 192.168.4.x. Clearly there would be a problem with this in that 172.20.0.x is already in use on the DMZ so you could either
1) map individual 192.168.4.x addresses to UNUSED 172.20.0.x addresses on the DMZ
OR
2) Use a totally different subnet instead of 172.20.0.x
Jon
John Blakley Mon, 12/15/2008 - 13:04
Thanks for the explanation Jon.
John
John Blakley Mon, 12/15/2008 - 12:48
You can do a couple of things:
Do a show xlate and look for the translation. If it's not there, try to run "clear xlate." (you'll lose existing connections, but they rebuild quickly.)
If you see the translation, try to run debug icmp trace. Ping the 192.168.4.0 host, and see what the firewall is reporting. If it's a translation issue, it will tell you.
HTH,
John
ronshuster Tue, 01/13/2009 - 09:26
Jon,
On your last reply you mentioned the following:
If there are no dynamic translations, how would a dmz device access the Internet?
In most cases DMZ nodes are accessed from the Internet but at the same time they require access to the Internet as well (to be initiated), how would you do that if not for the dynamic translation, ie. see nat above as well as the allowdmzout ACL.
Not sure if my problem is still solved, I have asked someone to initiate traffic from the DMZ to the inside (192.168.4.x) and I will then check the debug icmp as l.blakley suggested.
I didn't think that allowing a DMZ device access to a specific host or vlan restricted to a given port(s) is so complicated.
hunnetvl01 Wed, 01/14/2009 - 10:44
I have the same struggle with a PIX 6.3 , so dont worry its pretty complicated as in " IT DOESNT FRICKIN' WORK!"..
Anyway good luck with this!
Try this maybe :
NAT (DMZ) 1 172.20.0.0 255.255.0.0 outside
Global(Inside) 1 interface
For me it did not work, but people say it did the job for them...
Vlad
