Localization on CME (Call Manager Express)
Dec 4th, 2008
I'm using CME . I want to use greek locale for 7906, 7942, 7962.
I'm following the instructions according to this document:
and using the method with the Installer. The locale that i'm using is CME-locale-gr_GR- .
So every time i'm issuing the user-locale U1 load CME-locale-gr_GR- command i get the following error:
LOCALE INSTALLER MESSAGE:Loading Locale Package...
LOCALE ERROR: Failure renaming flash:/its/CME-locale-gr_GR- to flash:/its/user_define_1_CME-locale-gr_GR- ERROR#Unknown error 2573
%Error deleting flash:/its/CME-locale-gr_GR- (File not found)
I'm attaching sh run and some dir outputs to check my files.
I can;t understand what is happening. I cant find much of a use on cisco documentation.
Any help will be appreciated. Thank you
1 vote
stavropouloss Tue, 12/09/2008 - 00:50
does anyone has any knowledge to share? Has anyone faced that problem before?
Thank you
