Can you transfer a call using UPC7.0?
Answered Question
Dec 4th, 2008
Is it possible to transfer a call that you are on when using UPC? I can't figure out how to do it.
Thanks.
Correct Answer by Jonathan Schulenberg about 8 years 7 months ago
Yes but it's a little awkward.
1. Place your first call to party A.
2. Make a second call, this will put A on hold.
3. Once you are talking to B, press the Merge button on "A's" call control window. This will put you into a conference.
4. Hang up.
It should be noted that this uses a conference resource until you drop off. You'll need to ensure there are sufficient resources available.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Fri, 12/05/2008 - 03:37
  • Cisco Designated VIP,
    2017 IP Telephony
4. Hang up.
j.mccartney Fri, 12/05/2008 - 07:42
Thanks it works great, the only thing different from your steps is that I had to press the Merge button on party-B to transfer the call. The merge button for party-A was grey'd out.
thanks again!
