Autonomus AP config issues
Dec 4th, 2008
Hello, i'm configuring 3 AP 1131, with 2 profile Guest and Inoffice. the 3 AP are going to be connected to a 3560 and they are going to have Vlan and a 2811 is going to be configured as a DHCP.now all i can see when i search for available network is the guest SSID and if connect i don't get any Ip address. Any idea. I'm attaching the AP config. Thanks.
Marco Villani Fri, 12/05/2008 - 15:07
Hello, so i have setup MBSSID like below,but still my AP broadcast only one SSID,any suggestion?
dot11 ssid EP_Internal
vlan 3
authentication open
mbssid Guest-Mode
dot11 ssid EP_Guest
vlan 4
authentication open
mbssid Guest-Mode
interface Dot11Radio0
mbssid
no ip address
no ip route-cache
Marco Villani Sun, 12/07/2008 - 13:29
Yes I do ,below the config. thanks
version 12.3
no service pad
service password-encryption
hostname AP_01
clock timezone GMT -5
dot11 vlan-name Data vlan 3
dot11 vlan-name Data vlan 4
vlan 3
authentication open
Guest-Mode
dot11 ssid EP_Guest
vlan 4
authentication open
guest-mode
power inline negotiation prestandard source
Username Cisco password Cisco
class-map match-all _class_Data0
match ip dscp default
policy-map Data
class _class_Data0
set cos 0
bridge irb
no ip address
no ip route-cache
ssid Internal
ssid Guest
speed basic-1.0 basic-2.0 5.5 11.0 18.0 24.0 36.0 48.0 54.0
power local cck 17
power local ofdm 17
power client 17
channel 2412
station-role root
l2-filter bridge-group-acl
interface Dot11Radio0.668
encapsulation dot1Q 668 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
service-policy input Data
service-policy output Data
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 input-address-list 701
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
service-policy input data
service-policy output data
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 input-address-list 700
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.668
no ip route-cache
bridge-group 1
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface FastEthernet0.4
no ip route-cache
bridge-group 4
interface BVI1
ip address xxx.xxx.x.x 255.255.255.0
no ip route-cache
ip default-gateway xxx.xxx.x.x
no ip http server
bridge 1 route ip
line con 0
password cisco
login
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
transport output all
end
