problem accessing PIX using ADSM 5.1
Dec 4th, 2008
I am unable to accesss PIX using ADSm 5.1, after I logon, the error message show up: ASDM is unable to read the configuration from the PIX, please check the configuration and your connection and then try again by clicking the refresh icon.
I have turned off all the firewall... and it still got problem. I can telnet into the PIX...
I have uninstall and reinstall again as well.
any idea?
kind regards
husycisco Fri, 12/05/2008 - 05:37
Hello Rachel,
Make sure the user you are loging in has enough privilege level. Try with a priv 15 user or enable password by leaving username blank and entering enable password to password section.
rachelau_2005 Sun, 12/07/2008 - 16:07
The problem has been resolved now, it was due to the JAVA problem. it started working again after downgrade the java version.
Thanks you all
Kind regards
