AIR-WLC526-K9 Mobility Express Controller
Answered Question
Dec 4th, 2008
Can the AIR-WLC526-K9 be used for any other access points besides the AIR-LAP521G-A-K9 access points? Does the 526 controller use the LWAPP protocol?
Correct Answer by Rob Huffman about 8 years 1 month ago
Hi Nolan,
Sadly, the WLC 526 only supports the LAP 521. No other AP Models (like the 1131 or 1242) can be used in this solution. And vice versa the 521 will not work with other WLC Models like the 2106. The WLC 526 does use the LWAPP Protocol :)
Q. Which access point products are included in the Cisco Mobility Express Solution?
A. Two Cisco 500 Series Wireless Express Access Point products are in the Cisco Mobility Express Solution; their part numbers follow:
• AIR-AP521G-x-K9 (standalone access point)
• AIR-LAP521G-x-K9 (controller-based access point)
The hardware for these products is the same. The products have different software, but the access points can be converted from standalone mode to the controller-based mode with a simple software upgrade.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7306/ps7319/ps7338/prod_qas0900aecd8060c860_ps7320_Products_Q_and_A_Item.html
As a core element of the Cisco Mobility Express Solution, the mobility controller is built to specifically support the Cisco 500 Series Wireless Express Access Points.
http://www.cisco.com/en/US/products/ps7320/index.html
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
Correct Answer
Rob Huffman Fri, 12/05/2008 - 05:46
Hi Nolan,
Hope this helps!
Rob
nolan.bilgera Mon, 12/08/2008 - 19:14
It's funny how the WLC 526 uses the LWAPP Protocol but doesn't support LWAPP Access Points besides the LAP 521. That's Cisco for you.
Michal Gurbski Thu, 10/27/2011 - 02:37
Does AIR-WLC526-K9 Mobility Express Controller supports AIR-LAP1141N AP? Is it posible with Cisco Wireless LAN Controllers and Lightweight Access Points  5.2.193.0 software for AIR-WLC526-K9?
http://www.cisco.com/en/US/products/ps7320/prod_release_notes_list.html
Cisco 526 Wireless Express Mobility Controller Release Notes for  21/Jul/2011
AIR-WLC520-K9-5-2-193-0.aes
Release Date: 25/JUN/2009
Cisco WLC526 Mobility Express Controller.
Size: 22943.18 KB (23493816 bytes)
BTW:
The following new features are supported in the Wireless Express 5.2.157.0 release:
"Managed access points—The number of supported controller-managed Cisco 521 wireless access points increased from 6 to 12 per controller. Up to 24 total LAPs are supported in a dual-controller configuration."
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/c526rn52157.html
Kind regards,
Michał
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
