12-04-2008 08:49 PM
Dear friends
i am using LMS 2.6 and want to ask that the notification emails generated through various applications like RME, DMF etc have links like the one below;
Description : System config polling job
Details : https://cyberlms:443/rme/DcmaJobDetails.do?jobid=1009.34
My question is what would i need to do to change this domain 'cyberlms' to fully qualified domain 'cyberlms.mycompany.com'. ??
Is it the hsotname of Server machine its picking in URL?? or there is some setting in LMS to change??
please help
12-05-2008 11:01 AM
Please post NMSROOT/lib/classpath/md.properties.
12-16-2008 02:59 AM
Sorry for replying late... Here is the output of the md.properties.
NMSROOT=C:/PROGRA~1/CSCOpx
PX_BINDIR=C:/PROGRA~1/CSCOpx/bin
PX_CGIDIR=C:/PROGRA~1/CSCOpx/cgi-bin
PX_LOGDIR=C:/PROGRA~1/CSCOpx/log
PX_TMPDIR=C:/PROGRA~1/CSCOpx/temp
PX_DATADIR=C:/PROGRA~1/CSCOpx/files
PX_DOCDIR=C:/PROGRA~1/CSCOpx/htdocs
PX_CLASSDIR=C:/PROGRA~1/CSCOpx/www/classpath
PX_CGIURL=/cgi-bin
PX_DOCURL=/
PX_CLASSURL=/CSCOnm/classpath
PX_SCLASSDIR=C:/PROGRA~1/CSCOpx/lib/classpath
PX_DATASTORE=DSN=rme
PX_CLASSPATH=C:/PROGRA~1/CSCOpx/lib/classpath;C:/PROGRA~1/CSCOpx/www/classpath;C:/PROGRA~1/CSCOpx/campus/www/classpath;C:/PROGRA~1/CSCOpx/campus/lib/classpath;C:/PROGRA~1/CSCOpx/campus/www/classpath;C:/PROGRA~1/CSCOpx/campus/lib/classpath;C:/PROGRA~1/CSCOpx/campus/www/classpath;C:/PROGRA~1/CSCOpx/campus/lib/classpath
PX_APPDIR=C:/PROGRA~1/CSCOpx/objects
PX_CONFDIR=C:/PROGRA~1/CSCOpx/conf
PX_CTRBDIR=C:/PROGRA~1/CSCOpx/contrib
PX_HLPDIR=C:/PROGRA~1/CSCOpx/help
PX_LIBDIR=C:/PROGRA~1/CSCOpx/lib
PX_USER=casuser
PX_GROUP=casusers
PX_STOP_DELAY=3000
PX_SYS_CHECK=1
PX_OSA_PORT=42342
OSAGENT_PORT=42342
PX_HOST=cyberlms
PX_FQDN=cyberlms
ASANY=C:/PROGRA~1/CSCOpx/objects/db
SQLANY=C:/PROGRA~1/CSCOpx/objects/db
CORE_SECURE_PORT=443
CORE_NONSECURE_PORT=1741
PX_PROTOCOL=https
PX_PORT=443
PX_WEB_PORT=443
MAX_RAM=2048
MAX_SWAP=4096
MAX_CPU=1600
PX_ANI_PORT=42344
SYS_NO_OF_CPUS=2
SYS_RAM=4092
SYS_CPU=2666
SYS_SWAP=4092
12-16-2008 07:42 AM
I was having this same problem, so I updated the PX_FQDN to be the FQDN and the email links were correct. However, when the system rebooted (for a backup), the PX_FQDN variable in md.properties file was changed back to just the server name. Is there another location that needs to be updated?
12-16-2008 08:10 AM
Your PX_FQDN value is not a true FQDN. This should be changed in this file, and in the Registry (search for PX_FQDN). This variable should point to the server's fully-qualified hostname. After making these changes, restart CiscoWorks Daemon Manager.
12-16-2008 08:20 AM
Where would you change it on Solaris 9 in addition to the md.properties file?
12-16-2008 08:22 AM
/var/sadm/pkg/CSCOmd/pkginfo
12-16-2008 08:25 AM
thanks!
12-18-2008 11:14 PM
I tried it but failed... I started getting Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
i had to revert back the settings.... just a question that
my server name is = cyberlms
my fqdn is = lms.mycompany.net
do they have to be same??
what could be the reason??
12-19-2008 05:41 AM
Your FQDN must be cyberlms.mycompany.net. The FQDN is the short hostname plus the domain name. This must be resolvable in DNS.
