Interfaces up/down
Dec 5th, 2008
Could someone please explain if this behaviour is normal.
When a client connects it seems to go Down then Up then Down then Up again?
Any ideas?
When an interface goes up and down
Dec 5 08:48:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/14, changed state to down
Dec 5 08:48:27: %LINK-3-UPDOWN: Interface GigabitEthernet1/14, changed state to down
Dec 5 08:48:32: %LINK-3-UPDOWN: Interface GigabitEthernet1/14, changed state to up
Dec 5 08:48:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/14, changed state to up
Dec 5 08:48:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/14, changed state to down
Dec 5 08:48:37: %LINK-3-UPDOWN: Interface GigabitEthernet1/14, changed state to down
Dec 5 08:48:40: %LINK-3-UPDOWN: Interface GigabitEthernet1/14, changed state to up
Dec 5 08:48:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/14,
Davy Ad Fri, 12/05/2008 - 02:17
Hi Michael,
This is not normal , check your cable*
DAk
crow930us Fri, 12/05/2008 - 02:40
The issue seems to beat at the physical level or the data link level.
1. Ensure that the proper cables are being used.
2. Confirm the configuration settings on both sides of the link are correct. Verify the proper duplex and speed is configured. Check that the correct media-type is configured when applicable.
mikedelafield Fri, 12/05/2008 - 05:55
Could it be a feature of STP that the port comes up then goes down again?
I am not seeing any additional problems caused by this, it just seems strange?
inayathulla1 Fri, 12/05/2008 - 06:24
Is this happening to all the clients ? or with only one client ?
Have you already checked the cable and duplex settings on both the sides?
Inayath
mikedelafield Fri, 12/05/2008 - 07:16
most clients it seems. its not causing a problem its jsut something i have noticed in syslog
cabling and duplexing is okay. running 1gb. so auto detects to 1gb full as default
