IOS Software
Dec 5th, 2008
I have downloaded gns3 and i require CISCO IOS Software for it to operate. Foe the past 5 days i have been looking for it but unable to find. Can someone please guide me, i need to practice with the network simulator.
Thanking You.
miteshsharma02 Sat, 12/06/2008 - 06:02
The page says you are not entitled for this service. Is there any other alternate for this.
Thank you.
Teoh Chee Hin Tue, 10/04/2011 - 02:14
To download the IOS, you may need to have cisco partner reseller account or direct cisco partner only have the authority to download the IOS.
stephnane Mon, 01/23/2012 - 01:07
Hi all.
I regularly buy new Cisco hardware but I need to download iOS software. Is it possible to download with a Serial Number or something which is in the box ?
tks
Neeraj Arora Mon, 01/23/2012 - 04:15
  • Silver, 250 points or more
No..not with the serial number but if you bought a Support contract  with these devices then you can link these contracts in your Cisco  profile. Based on the contract, your user id will get the required  authorisation to access the IOS download page
Or another way is to use the IOS file from the Cisco  Routers bought (if they are of the same platform which GNS support) and  transfer it to the PC using TFTP
Hope it helps
