Can't add MARS device to CSM
k.dimitrovski
I'm trying to add a MARS to a fresh install of CSM 3.2.0 through the CSM client.
I constantly get the message:
Connection with CS-MARS failed.
Incorrect username or password.
Make sure the CS-MARS username and password are valid.
I'm sure that the credentials are OK.
I even created a new user in MARS dedicated to CSM.
The strange thing is that MARS doesn't have any logs of these login failures.
Here's a screenshot of the error:
https://dl.getdropbox.com/u/67172/Invalid_credentials_full.PNG
10 Replies 10
silvertrump
I use my pnadmin acct.
krir
Level 4
Level 4
Please check the following from the screen shot I understand that you are trying to add the MARS using a Global account
1) Make sure that you are able to login to GC or LC using this account.
2) If you are trying to add the LC to CSM using the GC account, make sure the User account replicted to the LC.
3) If you are trying to add a CS-MARS using useraccount which is integrated with AAA then check for Global Controller Considerations with External AAA Servers under
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/user/guide/combo/authen.html
From the screen shot I understand that you are trying to add the MARS using a Global account
All credentials are local, and it's only one LC.
I was using the standard pnadmin account, and after that crated another one just to be used for CSM.
I've opened TAC but no solution so far.
Then the User Type should be "Local" should not be "Global" (Please Check the screen shot which you attached)
Global should be used only when you are using GC in your setup
R.Krishnan
Sorry but I can't see where I can specify what kind of user I'm entering the credentials for.
Best regards,
K. Dimitrovski
Please see the attached screen shot for the option
Krir,
could you send me the attachment agnain, maybe on email: koki @ neocom.com.mk.
The cisco forums give me the: Document does not exist! error.
Best regards
Done
k.dimitrovski
Just to inform everybody.
I solved the problem through a TAC case.
The resolution was no to use special characters in the user's password!
They sent me this as a explanation:
"Yes this is normal. During parsing of password any special character is
being phased out, since we cannot reliably encode it."
This is nonsense to me but...
