PSTN access via pbx
Dec 5th, 2008
Dear all
we have our access to pstn via Ericcson pbx(MD110)
our callers want hear pstn dial tone after pressing 9.
right now they can access pstn but without hearing pstn dail tone
please let me any hint or idea.
thank you
Brandon Buffin Tue, 12/09/2008 - 12:06
  • Purple, 4500 points or more
Are you using Callmanager for call control? If so, you can check the "Provide outside dial tone" box on the route pattern(s) that point to the PBX for PSTN access.
Hope this helps.
Brandon
Nicholas Matthews Fri, 12/12/2008 - 17:55
  • Red, 2250 points or more
3 choices:
On CME:
secondary-dialtone STRING
Previously mentioned CUCM:
'Provide Outside Dialtone' on route pattern
On a gateway with a PRI:
dial-peer voice x pots
incoming called-number 9
That allows the user to hear dial tone from the router, and it will forward it from there.
This can also be done on the PBX, through their own means.
