How to upgrade netManager 1.0 to 1.1
Dec 5th, 2008
My customer bought netManager 1.0 IP Infrastructure with a licence for 50 devices. I would like to upgrade netManager to version 1.1.
How to upgrade netManager with a licence 50 device ?
I didn't find a patch.
Thanks.
drolemc Thu, 12/11/2008 - 12:58
  • Silver, 250 points or more
Before You Begin
• Confirm that your system meets the minimum software and hardware requirements listed in Server and Client System Requirements.
• Review Installation Notes.
Step 1 As the local administrator, log in to the machine on which you will install the Cisco
netManager software and insert the Cisco netManager 1.1 CD-ROM into the CD-ROM drive.
The Cisco netManager 1.1 Setup Program window opens.
Step 2 The installation wizard detects and displays the Cisco netManager version currently installed
on the system. A confirmation window prompts you to confirm the upgrade to Cisco
netManager 1.1.
Step 3 Click Yes to confirm the upgrade. The Welcome window appears.
Step 4 Click Next. The Choose Backup Location window appears.
Step 5 Do one of the following:
• Click Next to accept the default installation directory.
• Click Browse... to navigate to the folder where you want a backup of the existing
database stored. Click Next.
The Ready to Install window appears.
Step 6 Click Install to begin the upgrade.
Step 7 Click Finish when the installation is complete.
For further information click this link.
http://www.ciscosystems.com.pe/en/US/docs/net_mgmt/cisco_netmanager/1.1_data/quick/guide/CnM11QS_data.pdf
mauricio.rodriguez Thu, 12/11/2008 - 15:04
Thanks for the explanation.
How can I have ip netmanager 1.1 ?
Is it an free upgrade which I can download from Cisco.com ?
Or, have I to buy ?
Thanks.
