64 bit vista and VPN access
Dec 5th, 2008
the cisco vpn client is 32 bit only and I have an employee that needs to work remotely but she has 64 bit vista. Is there a third party program or other client to use?
shamilton-wilkes Fri, 12/05/2008 - 11:17
Our solution for this has been a VM running Windows XP 32 bit, just for VPN access. Only requires free VMware Player, and may be covered by your Select agreement MS licensing wise. Ugly but works OK.
dianewalker Fri, 12/19/2008 - 18:22
So, just download VMWare Player and install it on the XP and you were able to use Cisco VPN client?
Thanks.
Phillip Remaker Fri, 02/19/2010 - 11:19
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to cvc-beta@cisco.com.
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
