QOS - Packet Drops in Default-Class
Dec 5th, 2008
Hello Experts,
Below is the Standard QOS Configuration applied for my Major Customer. The recent complaint is, the Customer is experiencing the PACKET DROPS for the normal packets that are NOT classified, since they are preferring the default-class.
Request your Help/Advice in advance.
policy-map Customer-A
class class-default
shape average 256000
service-policy Customer-Child
policy-map Customer-Child
class Cust_class_EF
bandwidth percent 50
class Cust_class_AF
bandwidth percent 30
class Cust_class_AF1
bandwidth percent 20
class-map match-all Cust_class_AF
match ip dscp cs4
class-map match-all Cust_class_EF
match ip dscp ef
class-map match-all Cust_class_AF1
match ip dscp 29
interface GigabitEthernet0/3.123
description ***Customer-WAN**
encapsulation dot1Q 123
ip vrf forwarding 2000-Customer-MESH
ip address xx.xx.xx.xx 255.255.255.252
service-policy output Customer-A
end
Thanks.
Best Regards,
Guru Prasad R
Joseph W. Doherty Fri, 12/05/2008 - 07:57
Well you've defined 100% across all your named classes within the policy-map Customer-Child. This doesn't leave any reserved for the implicit class-default. (I'm surprised this policy is accepted since normally you shouldn't be able to define more that 75% unless you override the default 25% other traffic reservation, and I don't see that being done within your interface config snipet. Perhaps this policy is accepted because it's a subordinate policy.)
