Multicast and Rendevous Point
Dec 5th, 2008
I've just got onto a new contract where all the routers (150) are running OSPF routing domain. The old engineer stated that he had setup an RP on one of the routers, but can't remember which one.
All the router interfaces are running sparse-dense-mode.
Question:
How can I locate the current RP?
How can I setup an RP for just one multicast address?
This there a document that explain Rendevous Point?
Thank you in advance.
Jon Marshall Fri, 12/05/2008 - 08:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
David
Sorry but couldn't help laughing when i read the engineer said he'd set it up but couldn't remember which one - bit like needle in haystack :-)
1) do a "sh ip pim rp" should show you the active RP's in use -
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_06.html#wp1017020
Do you know if they are active ? Also do you know how he defined the RP ie.
i) statically on each router - guessing not as then you would have found it
ii) Bootstrap
iii) Auto-RP
2) Could you explain a bit more exactly hwat you want. You can use access-lists with RP to define which RP will be responsible for which group
3) RP is used with PIM sparse mode. Have a look at this link -
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/White_papers/mcst_ovr.html#wp1009081
Jon
Giuseppe Larosa Fri, 12/05/2008 - 11:55
  • Hall of Fame,
    Founding Member
hello Jon,
if the RP was manually configured the old times engineer should remember its IP address after having put the same command on all 150 routers in the OSPF domain !!
I use
sh ip pim rp mapping
RP equates IP PIM sparse mode.
Best Regards
Giuseppe
CriscoSystems Fri, 12/05/2008 - 11:58
  • Bronze, 100 points or more
I find myself NOT wondering why they put a new engineer on this one...
Jon Marshall Fri, 12/05/2008 - 11:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
"if the RP was manually configured the old times engineer should remember its IP address after having put the same command on all 150 routers in the OSPF domain !!"
You would think so wouldn't you !, maybe he is just a bit absent minded :-)
Jon
Giuseppe Larosa Fri, 12/05/2008 - 12:17
  • Hall of Fame,
    Founding Member
Hello Jon,
it is clear the old times engineer is not collaborative, it can be not easy to be from a human point of view.
However, in his next job he can be on the other side to be the one that has to continue somebody's else job.
Also the level of documentation about the network is important for the new taker: it is important to understand the level of detail, completeness and freshness of documents.
Can they be trusted ?
Are network maps reflecting the current state of backbone and sites ?
Can I access all network devices with my account(s) or there are special cases (for example firewalls just to say)
There are network design or architecture documents for example for multicast ?
Have been network incidents traced in some way?
Hope to help
Giuseppe
