No Outgoing Calls
Dec 5th, 2008
Hi Guys,
I am having trouble trying to setup outgoing calls through my gateway. Please see the below config:
dial-peer voice 21 voip
description **Incoming Calls to CUCM**
destination-pattern 2...
progress_ind setup enable 3
session target ipv4:192.168.5.253
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate disable
ip qos dscp cs3 signaling
no vad
dial-peer voice 31 pots
description **Incoming PSTN Calls**
translation-profile incoming Incoming
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 32 pots
description *** Outgoing PSTN Calls ***
destination-pattern 9.T
progress_ind alert enable 8
progress_ind connect enable 8
port 0/0/0:15
forward-digits 0
Debug isdn q931
001324: Dec 5 16:18:39.312: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 805B015DEBE0E11D22001B02C0A81502, SetupTime 16:18:39.252 UTC Fri Dec 5 2008, PeerAddress 2571, PeerSubAddress , DisconnectCause 1 , DisconnectText unassigned number (1), ConnectTime 16:18:39.312 UTC Fri Dec 5 2008, DisconnectTime 16:18:39.312 UTC Fri Dec 5 2008, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
001325: Dec 5 16:18:39.312: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:12/05/2008 16:18:39.252,cgn:2571,cdn:123,frs:0,fid:109,fcid:805B015DEBE0E11D22001B02C0A81502,legID:6D,bguid:805B015DEBE0E11D22001B02C0A81502
Debug Voice Dial-Peer
001332: Dec 5 16:23:11.644: //-1/00DAB9FF2600/DPM/dpAssociateIncomingPeerCore:
Calling Number=2571, Called Number=123, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
001333: Dec 5 16:23:11.644: //-1/00DAB9FF2600/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=21
001334: Dec 5 16:23:11.644: //-1/00DAB9FF2600/DPM/dpAssociateIncomingPeerCore:
001335: Dec 5 16:23:11.644: //-1/00DAB9FF2600/DPM/dpAssociateIncomingPeerCore:
001336: Dec 5 16:23:11.648: //-1/00DAB9FF2600/DPM/dpMatchPeersCore:
Calling Number=, Called Number=123, Peer Info Type=DIALPEER_INFO_SPEECH
001337: Dec 5 16:23:11.648: //-1/00DAB9FF2600/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=123
001338: Dec 5 16:23:11.648: //-1/00DAB9FF2600/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
001339: Dec 5 16:23:11.648: //-1/00DAB9FF2600/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
001340: Dec 5 16:23:11.684: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId DAB9FFEBE0E11D26006302C0A81502, SetupTime 16:23:11.644 UTC Fri Dec 5 2008, PeerAddress 2571, PeerSubAddress , DisconnectCause 1 , DisconnectText unassigned number (1), ConnectTime 16:23:11.684 UTC Fri Dec 5 2008, DisconnectTime 16:23:11.684 UTC Fri Dec 5 2008, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
001341: Dec 5 16:23:11.684: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:12/05/2008 16:23:11.644,cgn:2571,cdn:123,frs:0,fid:113,fcid:DAB9FFEBE0E11D26006302C0A81502,legID:71,bguid:00DAB9FFEBE0E11D26006302C0A81502
I have a route pattern 9.@ and 9.123 for testing purposes on the call manager.
Any help will be greatly appreciated.
vhilario Sat, 12/06/2008 - 14:23
What's your callmanager version?
What kind of gateway r u using, H323 or MGCP?
For outgoing calls should match the dial-peer voice 32 pots
What do you hear when you dial the 9 and the local digits?
How many digits is the TELCO expecting?
Be sure that the CSS of your phones can reach the partition of the route pattern you are using.
Have you run a debug on the gateway? have you see that outgoing calls are going through gateway?
Can you run an ISDN q931 debug and post it, if you are using an MGCP gateway.
If not please run the following debug "voip ccapi inout"
Viri
CHRIS CHARLEBOIS Mon, 12/08/2008 - 13:23
  • Silver, 250 points or more
From the debug, it looks like you are stripping the 9 (pre-dot, I assume, based on your comment of 9.123) at the CallManager before it hits the VG. But the VG is expecting that 9 to be there to match dial-peer 32. I can see that the called number on the trace your provided is 123, not 9123.
I would recommend not stripping the 9 at the CallManager and making sure that digit-strip is enabled on that POTS dial-peer. (It's on by default) BTW, that 9.T looks alot like would you would use in the CCM route pattern to remove the 9 pre-dot, but it means something else in the dial-peer. That '.' in the dial-peer is a wildcard and is not neccessary. The T is going to wait for the timeout anyway.
Personally, I avoid the T option like the plague. If you live in a country with a predictable length numbering plan (like NANP), I would recommend putting in fixed length dial-peers. Only use the T option for international calls.
Nevermind... Looks like you are using an E1, so I'm guessing it's not the NANP.
