Privilege levels and radius
Dec 5th, 2008
I have configured radius authenication and have 2 types of users - 15 - all access and 2 limited access.
The problem I am experiencing is controlling enable mode access.
If the radius server stops then the default username Test1 is used and although I have configured it for level 15 it is always level 1 when you show privilege. From there you can go to enable mode. Which is what I want. (is that best practice?)
When radius server is up, then Test2 can login and gets privelege level 2 with limited commands. Except that you can access the enable mode. I tried
'privilege exec level 10 enable' but then the Test1 cannot get enable mode.
I tried 'aaa authentication enable default group radius enable' and it goes to the radius server to get authenication for enable password but I want to stop Test2 from being able to use the enable command and getting a password request.
Any clues how to do this?
enable secret 5 xxxxxxxx
username Test privilege 15 password 7 xxxxxx
aaa new-model
aaa authentication login radius-login group radius local
aaa authorization console
aaa authorization exec default group radius if-authenticated
aaa authorization network default group radius
aaa accounting exec default start-stop group radius-login
aaa accounting network default start-stop group radius-login
aaa accounting system default start-stop group radius-login
radius-server host x.x.x.x auth-port 1812 acct-port 1813
radius-server key 7 yyyyyyyyyy
privilege exec level 2 traceroute
privilege exec level 2 ping
privilege exec level 2 clear counters
privilege exec level 2 show interfaces
privilege exec level 1 show privilege
Overall Rating: 5 (2 ratings)
mchin345 Thu, 12/11/2008 - 10:03
  • Silver, 250 points or more
The privilege level for certain commands, and provides an example with parts of sample configurations for a router and TACACS+ and RADIUS servers.
By default, there are three privilege levels on the router.
- Privilege level 1 = non-privileged (prompt is router>), the default level for logging in
- Privilege level 15 = privileged (prompt is router#), the level after going into enable mode
- Privilege level 0 = seldom used, but includes 5 commands: disable, enable, exit, help, and logout
Levels 2-14 are not used in a default configuration, but commands that are normally at level 15 can be moved down to one of those levels and commands that are normally at level 1 can be moved up to one of those levels. Obviously, this security model involves some administration on the router.
For further information click this link.
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a008009465c.shtml
