IPM failed on add HTTP operations
Dec 5th, 2008
I am experiencing problem when I try to add http operation in collectors. I have a Cat 3560 IP SLA setup as sources and trying to get HTTP IPM to work. I added the http operations by -> HTTP -> URL Lookup http://www.cisco.com. When I tried to add collection that associated source (3560) to operations (cisco.com) I getting this error box and back to IPM: Configuration menu.
IPM: Error Dialog Box
AddCollErrtest
REASON: Invalid Value Specified
LMS version 2.6
IPM 2.6.0
I able to see the IP SLA entry in 3560 but the ip of cisco shows up as 0.0.0.0
Any suggestions are greatly appreciated.
=JL=
3560#show ip sla configuration 17846
IP SLAs, Infrastructure Engine-II.
Entry number: 17846
Owner:
Tag:
Type of operation to perform: http
Target address/Source address: 0.0.0.0/0.0.0.0
Target port/Source port: 80/0
Operation timeout (milliseconds): 5000
Type Of Service parameters: 0x0
HTTP Operation: get
HTTP Server Version: 1.0
URL: http://www.cisco.edu
Proxy:
Raw String(s):
Cache Control: disable
Schedule:
Operation frequency (seconds): 60
Next Scheduled Start Time: Pending trigger
Group Scheduled : FALSE
Randomly Scheduled : FALSE
Life (seconds): Forever
Entry Ageout (seconds): 3600
Recurring (Starting Everyday): FALSE
Status of entry (SNMP RowStatus): notInService
Threshold (milliseconds): 5000
Distribution Statistics:
Number of statistic hours kept: 2
Number of statistic distribution buckets kept: 1
Statistic distribution interval (milliseconds): 20
History Statistics:
Number of history Lives kept: 0
Number of history Buckets kept: 15
History Filter Type: None
Joe Clarke Fri, 12/05/2008 - 11:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
First, your 3560 must be running 12.2(40)SE or higher as this was the first release to officially support IP SLA. Second, the URL name you're using, http://www.cisco.edu is not valid. Third, the switch must be configured with a DNS server first that is capable of resolving the URL hostname. For example:
ip name-server 10.1.1.1
Once those things are in place, the operation should work correctly.
jayshihlin Fri, 12/05/2008 - 12:01
Hi Jclarke,
Thanks for promptly reply. I am sorry that there was a mistaken in copy & paste because I copied the wrong entry number...
IOS:
I am running 12.2(46)
System image file is "flash:/c3560-advipservicesk9-mz.122-46.SE.bin"
Domain Name:
Name-server was defined already.
I have dns resolver collection in IP SLA which is working fine. Name-server and collector are the same ip address.
3560#show ip sla config 3518
Entry number: 3518
Owner:
Tag:
HTTP Operation: get
URL: http://www.cisco.com
Proxy:
Raw String(s):
Schedule:
Next Scheduled Start Time: Start Time already passed
History Statistics:
Joe Clarke Fri, 12/05/2008 - 12:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Everything looks okay here except the SNMP row status. Once the collector has been scheduled, the row status should go to active. This might be a problem with your IPM configuration for this collector. Post a sniffer trace of all SNMP traffic to this switch when configuring your collector from IPM.
jayshihlin Fri, 12/05/2008 - 15:00
Just a curious.. I have DNS, PathEcho, DHCP, IPEcho, and TCP port 80 to MIT.edu. Every entry works expect http. If SNMP packet drop between ciscowork and 3560, should this happen on all entry?
One more though, Can I manually configure IP SLA in the 3560 and have CiscoWork IPM pull or link collector with 3560 rather than push configuration from CiscoWork? Perhaps upgrade to new IPM can help?
Thanks again!
Jay
Entry number: 10879
Owner: 88|ipm-ful-cw2k-Unknown
Tag: IPSLA_143a255_M
Type of operation to perform: tcp-connect
Target address/Source address: 18.7.22.69/0.0.0.0
Type Of Service parameter: 0x0
Operation timeout (milliseconds): 60000
Control Packets: disabled
Schedule:
Operation frequency (seconds): 61
Status of entry (SNMP RowStatus): Active
History Statistics:
Enhanced History:
Entry 3518 is http to cisco.com
3560##show ip sla stat
Round Trip Time (RTT) for Index 3518
Number of successes: Unknown
Number of failures: Unknown
Operation time to live: 0
Round Trip Time (RTT) for Index 5013
Latest RTT: 8 ms
Latest operation start time: 14:52:10.464 PST Fri Dec 5 2008
Latest operation return code: OK
Number of successes: 22
Number of failures: 0
Operation time to live: Forever
Round Trip Time (RTT) for Index 7097
Latest RTT: 125 ms
Latest operation start time: 14:52:07.654 PST Fri Dec 5 2008
Number of successes: 5
Number of failures: 3
Round Trip Time (RTT) for Index 10398
Latest RTT: 2 ms
Latest operation start time: 14:53:06.231 PST Fri Dec 5 2008
Number of successes: 60
Round Trip Time (RTT) for Index 10879
Latest RTT: 100 ms
Latest operation start time: 14:52:53.632 PST Fri Dec 5 2008
Number of successes: 27
Joe Clarke Fri, 12/05/2008 - 15:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is why I requested a packet capture in my previous reply.
jayshihlin Mon, 12/08/2008 - 11:45
Hi Joe,
I have the wireshark captured between SLA switch and Ciscowork. Since information is kind of sensitive I am wondering if I can email or PM you instead post here?
=J=
Joe Clarke Mon, 12/08/2008 - 11:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you cannot post the trace, then you will need to open a TAC service request with the information.
Joe Clarke Fri, 12/05/2008 - 15:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The ability to import collects from devices is in IPM 4.1 using the CLI command "ipm importcollector".
jayshihlin Mon, 12/08/2008 - 11:52
Okay, I will try upgrade IPM to newer version and see if it works.
=J=
