Adding a User to a Group??
Dec 5th, 2008
Does any one know the SOAP / AXL to add a user to a group?
When Adding a user, I'm specifying the group / name but the user does not get added to the group...
Sascha Monteiro Sun, 12/07/2008 - 10:30
The usergroup is not used when adding a user,
if you look at the XUser you see it's read-only.
The updateUserGroup could be used, but you need to specify all existing users, so that would be a bit tricky...
I think you need to use executeSQLUpdate, and add the association via sql.
You need to look at the datadictionary to see whcih table/fields to use.
