polycom behind the asa.
Dec 5th, 2008
Hi. i try to configure an static pat to get access to a polycom service.
Im trying to use a police nat but it doesnt work.
object-group service LIFESIZE-UDP udp
port-object range 60000 64900
port-object eq sip
object-group service LIFESIZE-TCP tcp
port-object eq h323
port-object range 60000 64999
port-object eq www
object-group service POLYCOM-TCP tcp
port-object eq h323
port-object range 3230 3270
object-group service POLYCOM-UDP udp
port-object range 3230 3253
access-list VIDEOCONFNATPORTS extended permit tcp host 10.1.1.7 object-group LIFESIZE-TCP interface outside object-group LIFESIZE-TCP
access-list VIDEOCONFNATPORTS extended permit udp host 10.1.1.7 object-group LIFESIZE-UDP interface outside object-group LIFESIZE-UDP
access-list VIDEOCONFNATPORTS extended permit tcp host 10.1.1.7 object-group POLYCOM-TCP interface outside object-group POLYCOM-TCP
access-list VIDEOCONFNATPORTS extended permit udp host 10.1.1.7 object-group POLYCOM-UDP interface outside object-group POLYCOM-UDP access-list VIDEOCONFNATPORTS extended permit tcp host 10.1.1.7 object-group LIFESIZE-TCP interface outside object-group LIFESIZE-TCP
static (inside,outside) interface access-list VIDEOCONFNATPORTS
I try to modify this and change the order of inside and outside, and i try to made this only with one port only like a test to reduce the complex.
But im not sure if i can get control in a static pat for a range of ports.
Of if someone have any advise to make this please tell me.
Thanks a lot.
Overall Rating: 1 (1 ratings)
