AIRONET 1242AG from wep to WPA2-PSK
Dec 5th, 2008
Hi, I have several AP, each one of them on a each department of my building.
Each AP is connected to a switch, AP's are using WEP but I want to migrate to WPA2-PSK
I have gone through the following link
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43auth.html#wp1048777
But it's not pretty clear to me.
My questions are:
1-Should I make some changes also on the switches where the AP are connnected to, or should I just swap from WEP to WPA2-PSK?
2- Does anyone has a step by step configuration for WPA2-PSK?
Overall Rating: 5 (1 ratings)
gamccall Fri, 12/05/2008 - 21:05
  • Silver, 250 points or more
1) nothing changes upstream from the AP.
2)
dot11 ssid Your_SSID
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 Your_WPA_Key
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid Your_SSID
Obviously, delete any wep keys from d0 config.
vhilario Wed, 12/10/2008 - 17:18
Thanks a lot for your help, I really appreciate it.
