Media Fetch Error
luai
I have CVP3.1 H323, my application server log keep showing these errors
Media Fetch Error for url=http://10.0.232.15/en-gb/sys/no_entry_error.wav: call:187CCC40.C2B311DD.B6370007.0E58952A
127417228: Dec 06 12:54:52.125 GMT+300 %ISN-SS_TEL-4-WARNING: Media File cannot be located for call: 187CCC40.C2B311DD.B6370007.0E58952A
5 Replies 5
geoff
Level 10
Level 10
The obvious question - can you fetch that WAV file using a browser? Can the gateway ping that IP address?
The no_entry_error.wav file is played when a caller in a microapp (Get Digit, Menu) makes no entry within the timeout window and does so a number of times, equal to the retry setting in the configuration. I'm sure you know this.
Geoff
dear Geof
many thanks for your Continuous support , but can you explain more?, also note that this error come with some other wav files also not just no_entry_error.wav
Can you paste the URL into your browser and the WAV file plays with your browser plug-in?
Can you log into the router and ping the IP address of the media store?
Has anyone substituted a WAV file that is not recorded in CCITT uLaw?
What is common across the files that won't play?
Geoff
every thing you mentioned is working fine but
when I enabled the content expiration feature, I got some memory errors on the VG stating that the memory pool is full, I want to know how much I should increase the memory pool and the IVR prompt memory in order to get it working ok these are the current statistics of the VG memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 636CDB40 345187512 146768456 198419056 181657724 161743760
I/O 20000000 134217216 56003924 78213292 78213292 78211324
and these are the config on the VG
http client cache memory pool 15000
ivr prompt memory 16384
Max is
ivr prompt memory 16384 files 1000
so that's OK.
The max setting for the http client cache is 50000 (5,000 kbytes). If you have enough RAM to play with in the router, use the max setting. This will surely require a reload of the router, which will clear the cache and you will be starting from scratch.
Geoff
