All mgmt users, even lobbyadmin and read only, login as admin
I have a 4402 and last night there was a power issue and I believe the controller rebooted. Now if we login using the lobbyadmin account, which is set as a lobbyadmin, it logs in as an admin. I have removed that account and readded it. I also added a test account as readonly and it also logged in as admin. Any help would be appreciated. Thanks.
5 Replies 5
Rob Huffman
Hi Jeremiah,
This sounds like a bug. Can you please tell us what WLC version you are running.
Rob
Sorry. The version is: 4.2.173.0
Jeremiah
Hi Jeremiah,
No worries my friend! I spent some time looking but I cannot find the bug (if it is) related to this. Here was the closest, but it should be fixed in your version;
CSCsj21554 Bug Details
WLC: Information leak via lobby admin accounts: read access to config
Symptom:
Lobby account users, after login in controller, can see WLC configuration by using each section URL, instead of following the restricted web interface.
Conditions:
Wireless LAN Controller with user accounts in the LobbyAdministrator group.
Workaround:
Users of an affected system can workaround this bug by removing LobbyAdministrator accounts.
Status
Fixed
Severity
2 - severe
Last Modified
In Last Year
Product
Cisco 4400 Series Wireless LAN Controllers
Technology
1st Found-In
4.1(176.6)
Fixed-In
4.1(176.34)
4.1(177.0)
4.1(181.0)
4.2(46.0)
5.0(68.0)
4.2(61.0)
5.0(148.0)
Sorry man, I would go ahead and open a TAC Case,
Rob
Thanks for your help Rob. I opened a TAC case and they told me to upgrade to 4.2.176. Again, thank you.
Hi Jeremiah,
You are most welcome my friend! Good work on the TAC Case.
Cheers!
Rob
