svi for vlan
Answered Question
Dec 6th, 2008
  • Bronze, 100 points or more
hi everybody!
I just want to know if we have to use" no shutdown" command or not in follwing config:
switch(config) vlan 100
switch(confg-vlan) name zee
switch(Config-vlan) exit
switch(config) int vlan 100
switch(config) ip address 10.10.10.10 255.255.255.0
Is this interface being virtual up by default?
thanks !
Correct Answer by Edison Ortiz about 8 years 7 months ago
It depends on the hardware.
Catalyst 3550, 3560 and 3750 are up by default.
Catalyst 4500 and 6500 are shutdown by default.
And even within the above mentioned hardware the behavior may be different in different IOS. The ones I tested came up with my findings from above.
When in doubt, a quick show ip int brief is recommended.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Sat, 12/06/2008 - 22:10
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
