MPLS @ Dynamips
Dec 7th, 2008
I would like to learn MPLS using my lab setup with dynamips. If someone could provide me with some case study/configuration/topology to simulate the same, that would be very helpful..
Thanks in advance
AneesH
Overall Rating: 3 (2 ratings)
royalblues Mon, 12/08/2008 - 00:26
Attached a simple MPLS topology i had created when i started studying MPLS
The forum mentioned above is a very good source though.
Narayan
aneesh.ts Mon, 12/08/2008 - 01:45
Jayaprakash and Narayan,
Thank you very much for your comments.....
tarjbains Thu, 12/11/2008 - 15:55
u can create ur own topoly in dyanagan note pad file as any normal routing topolgy just have to enable MPLS IP command. use 3660 router best router to use MPLS on daynagen cus it doesnt take much memory n supprot all command MPLS VPN n TE
aneesh.ts Fri, 12/12/2008 - 03:34
Thanks bains for your update on 3660.
Will surely try that out and let you know.
AneesH
