12-07-2008 11:25 AM - edited 03-04-2019 12:37 AM
i have a 1721 (c1700-advsecurityk9-mz.124-23.bin running on it) with strange NAT behaviour.
here is the corresponding config.
interface FastEthernet0
ip address 192.168.68.254 255.255.255.0
ip nat inside
no ip virtual-reassembly
speed 100
full-duplex
interface Serial0
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip nat outside
ip nat inside source list nat_to_internet interface Serial0 overload
ip access-list extended nat_to_internet
permit ip 192.168.68.0 0.0.0.255 any
so it is a very simple nat config. nothing special.
my problem is if ping a host on the public internet from any of the devices connected to the inside interface of the router then it works
But if i try to ping anything on the net from the router themself, it fails.
see:
ping google.com source fastEthernet 0
Sending 5, 100-byte ICMP Echos to 74.125.45.100, timeout is 2 seconds:
Packet sent with a source address of 192.168.68.254
Success rate is 0 percent (0/5)
any idea would be appreciated.
thanks
12-07-2008 12:34 PM
I've never tried that but i suspect the issue is the packet is not entering the inside interface and so bypasses the "ip nat inside" statement on your fa0 interface.
What does "sh ip nat translations" show when you try the ping from the router with fa0 as source interface ?
Jon
12-07-2008 12:54 PM
it should work as it is working seemless on my 831
see:
C831#ping google.com source ethernet 0
Translating "google.com"...domain server (79.121.0.2) [OK]
Sending 5, 100-byte ICMP Echos to 72.14.205.100, timeout is 2 seconds:
Packet sent with a source address of 192.168.250.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 120/125/128 ms
Pro Inside global Inside local Outside local Outside global
icmp xx.xx.x.xx:24 192.168.250.1:24 72.14.205.100:24 72.14.205.100:24
so it works on my C831 but not on my 1721 and i can't figure out what i am missing.
and the corresponding nat translation is:
12-07-2008 01:01 PM
okay, looks like i was wrong then :-)
On the 1720 what does a "sh ip nat translation" show ?
Jon
12-07-2008 01:06 PM
nothing about the ping. anyway here is the output
#sh ip nat translations
tcp xxx.xxx.xxx.xxx:32820 192.168.68.2:32820 81.183.105.116:19565 81.183.105.116:19565
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 67.83.46.162:57845 67.83.46.162:57845
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 71.197.2.219:37266 71.197.2.219:37266
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 71.229.226.123:3346 71.229.226.123:3346
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 76.27.77.174:37437 76.27.77.174:37437
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 76.118.108.152:31429 76.118.108.152:31429
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 76.250.66.180:45836 76.250.66.180:45836
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 78.98.26.101:21850 78.98.26.101:21850
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 81.236.227.18:27007 81.236.227.18:27007
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 83.143.38.23:36729 83.143.38.23:36729
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 84.1.163.74:47490 84.1.163.74:47490
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 85.11.157.124:48796 85.11.157.124:48796
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 86.1.133.46:28738 86.1.133.46:28738
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 86.61.51.173:61372 86.61.51.173:61372
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 88.216.126.136:34350 88.216.126.136:34350
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 94.44.1.52:29795 94.44.1.52:29795
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 98.203.152.135:63002 98.203.152.135:63002
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 98.204.81.99:25431 98.204.81.99:25431
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 128.122.10.68:10918 128.122.10.68:10918
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 142.51.211.7:61343 142.51.211.7:61343
udp xxx.xxx.xxx.xxx:32839 192.168.68.2:32839 219.122.216.128:14679 219.122.216.128:14679
tcp xxx.xxx.xxx.xxx:33012 192.168.68.2:33012 217.76.114.233:443 217.76.114.233:443
tcp xxx.xxx.xxx.xxx:33015 192.168.68.2:33015 81.190.34.165:443 81.190.34.165:443
12-07-2008 01:18 PM
Don't know whether it's IOS related, platform related (unlikely), feature set related. I have a 2600 router that i can boot up tomorrow and see what behaviour i get.
Jon
12-07-2008 01:20 PM
that would be nice. thank you for your efforts.
12-07-2008 08:32 PM
sorry wrong post
