CVP - ICM Integration
Answered Question
Dec 7th, 2008
Might be avery silly question I am going to ask, but I was thinking about it that:
A call comes on to VGW, matches a 'session target ras' dial peer and the GW as we have configured it to, redirects it to the CVP Call Server, and the CVP Call Server sends a New Call Route Request to ICM and the ICM triggers a script on the basis on the DN... the question is how does CVP know where the ICM is and what IP is it?
I know ICM has a CVP PIM (but its the ICM config pointing to CVP) and the CVP Ops Console - Call Server has a ICM tab configuration - but we do not tell CVP the IP of the ICM there or in the VBAdmin configuration or anywhere, so how does CVP Call Server figures out the IP of ICM at the first place to send it a New Call Route Request?
Correct Answer by geoff@hp.com about 8 years 2 months ago
Since you are using H.323, you can avoid asking the gatekeeper for the address of the voice gateway if (and only if) the ingress gateway is the same router as the VXML gateway (branch office deployment).
To do this, configure the CVP VB (H.323 service) using VBAdmin and specify the "SetTransferLabel 8111111111" setting.
See CVP 4.1 Config Guide p.418.
If the ingress gateway and the VXML gateway is not the same, your current method is correct.
Geoff
Overall Rating: 5 (1 ratings)
geoff@hp.com Sun, 12/07/2008 - 14:46
The PIM on the PG looks for the ICM service on the Call Server and tries to connect to it.
The PIM is configured with the hostname/IP address of the Call Server and a port to connect on - typically 5000. Likewise, the Call Server is configured with port 5000 - on the ICM tab of the Ops Console.
The PIM is always looking for the Call Server to start up - and when it gets a connection, the hand shake is set up. So now the ICM service knows where to send the New Call.
Try this - shutdown the Call Server from the Ops Console and watch the PIM trace. You will see it regularly reaching out to the Call Server on port 5000, trying to bind.
The next question you need to ask is - how does the Call Server know where (which gateway) to send the IVR transfer label (typically 8111111111) to start the VXML/VRU leg of the call. ;-)
Geoff
kartik.bhatia@w... Mon, 12/08/2008 - 05:41
Thanks Geoff
NO that I know, the Call Server asks teh GK, and in the GK I have configd a command 8111* to go to the registered VxMLGW.
Correct Answer
geoff@hp.com Mon, 12/08/2008 - 07:55
Geoff
