Imported users from CUCM into Unity Connection 7
Dec 7th, 2008
What is the default password for users imported from Call Manager into Unity Connection 7?
Bradford Magnani Sun, 12/07/2008 - 18:15
The password should be set by the user template that you specified when you imported the users.
Prior to importing users, you must do the following on the Cisco Unity Connection server:
•Edit or add a user template. In the Phone System field for the template, select the Cisco Unified CM server from which you are importing users.
Hope this helps. If so, please rate.
