Controller & service module
Answered Question
Dec 7th, 2008
what is a controller & service module ?
and what is the functional difference between them ?
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Abijit,
in a WAN router a controller controls an hardware resource like an E1/T1 or DS3 by controlling all OSI Layer1 parameters like clock (internal|line) line code used, the way that the link is used (for E1/T1 how the DS0 are used).
The configuration of the controller object generates logical interfaces that are in the case of E1/T1 groups of DS0 timeslots.
In a WAN router you can find network modules that are daughter cards that you can insert into the router. The level of modularity and flexibility is high because this network modules can host submodules like WICs VWICs and son
see
network modules, WAN modules, etherswitch modules under
http://www.cisco.com/web/psa/products/index.html?c=268437717
The term service modules is used instead for multilayer switches modules like CSM, FWSM, NAM..
see
http://www.cisco.com/en/US/products/hw/modules/ps2706/tsd_products_support_series_home.html
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Mon, 12/08/2008 - 10:04
  • Hall of Fame,
    Founding Member
Hello Abhijit,
please provide more details in order to get better help.
What kind of platfom are you referring to?
A multilayer switch like C6500 where service modules are special purpose linecards for example or a wan router ?
What technology are you referring to?
A WAN technology were we deal with T1/E1, DS3 controllers that allow to support for example channelized DS3 ?
This can help narrow the set of possible answers.
Hope to help
Giuseppe
napolean007 Tue, 12/09/2008 - 06:58
I am referring here regarding a WAN router.
Basically what is the function of a controller..?? & whats the difference between a controller & a service module ?
Correct Answer
Giuseppe Larosa Tue, 12/09/2008 - 14:22
  • Hall of Fame,
    Founding Member
Hello Abijit,
see
see
Hope to help
Giuseppe
