Giuseppe Larosa Mon, 12/08/2008 - 08:56
Hello Faizan,
if you mean what routes you shouldn't accept on an eBGP session describing Internet the routes that shouldn't be accepted are called bogons:
you should at least:
deny = not accept your own public prefixes
deny = not accept any private IP address as per RFC 1918
see for more information
http://www.nanog.org/mtg-0501/pdf/deitrich.pdf
if instead you mean what routes are good in a BGP table just check the first lines of show ip bgp
installed routes are also present in the routing table in the BGP table are marked as:
example
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i3.0.0.0 xx.yy.5.178 70 0 701 80 i
* zz.kk.234.137 70 0 3549 701 80 i
the first path is preferred
Hope to help
Giuseppe
Faizan Shaikh Tue, 12/09/2008 - 23:12
Friends,
It would be more specific if i say 'Corrupt BGP routes'.
Thanx Giuseppe for your help, it helped me a lot.
